Discuss SWA Cavity Wall Exit in the UK Electrical Forum area at ElectriciansForums.net
Hi guys. Just after some advice on what you think the best way of getting swa through a cavity wall.
Do you use just use T&E, conduit and wiska boxes before transfering to swa or just go straight through with the SWA? What do you think the tidiest method is?
I only ask as I'm running power to a hot tub and the swa cable will need to come out above the front door so easily visible.
Thanks in advance
Thanks in advance
I have recently run a supply to a shed and glanded the SWA in to one of these which was sprayed black,
with a rubber gasket over the top.
Cut a hole out the back of the conduit box and thread some plastic or steel conduit on the back and poke throught the wall. Can then run the cores in conduit/trunking etc back to the board.
Looks tidier than a wiska box IMO
Reply to SWA Cavity Wall Exit in the UK Electrical Forum area at ElectriciansForums.net
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
For various reasons out of my control, we have wound up in a situation where we have 1.5mm SWA cables buried in these pillars and exiting out of...
7K
Hello, I am an enthusiast amateur undertaking wiring of two outbuilding under a building notice. I am soon to be subject to a first fix inspection...
Hi all. Just a quick one if I may. I am currently about to fit 3 gang smart touch switch at my front door but owing to powering two sets of...
Hi All I would appreciate some help with a few questions here regarding cables sizing, I'm using the latest 18th edition, amendment 2. Q1...
