V
VMan
ok guys, not done much work with swa, so here's a simple q for ya'll.
Im putting a Submain into a garage, with isolator next to main DB (inside house).
First off, i will run 4mm 3 core SWA, being routed through brick wall and run horizontally to garage, direct clipped to wall. do i need a drip loop on outside wall? ( I think so? but hope not!
hone
SWA will terminate into isolator (inside building) and then use 4mm T+E to spare fuseway in DB.
2nd, Q, as one core will be cpc, when i terminate the SWA in the isolator, should i link together the SWA with the CPC using a fly lead?
And this only needs to be done on one end of the SWA, i.e no need to link SWA to CPC lead in garage, if done in house?
i have read posts where it should be bonded and run its own bonding conductor, but cannot see wy this is necessary.
Thanks in advance
v
hone
Thanks in advance
v
