Discuss SWA in drain permissable? in the UK Electrical Forum area at ElectriciansForums.net
dksanders
Hi All,
I've been asked to get a supply for a car park PIR light across the car park entrance from the existing light. The only way across would be by running the SWA cable in a drain that runs across the driveway (see picture).
Is there any reason that I shouldn't do that? I can't think of any regulation of the top of my head that prohibits it.
TIA
A drain is for drainage and not for cable runs as far as I’m concerned.
It’s a bit rough I’d say as I don’t like the idea of water in contact and maybe covering the cable.
Also proximity to other services although not water pipes I wouldn’t do it.
Compacted debris will build up over time, and traffic will compress it into the SWA...sharp gravel, sand, general grit and debris...doesn't look like a great idea...
however, running it in a steel conduit?
It looks like that drain is starting to break up anyway. The cement is cracking around it. Not a good future for the cable. Maybe use it and dig deeper than. But regs say 450mm don't they?
I'd be tempted to break out the concrete one side of that drain, lay the swa in some plastic ducting, then concrete over. You may find that existing concrete breaks out really easily, and at least then the cable can be withdrawn/replaced easily in the future.
Hi - I wouldn't do it - I could reasonably foresee the gully needing cleaning out and or collapsing. And then there's the warning tape ...
There are no other services in the drain
isn't warning tape only required when the cable is buried? as the cable would be sat in the bottom of the concrete trench and protected by the cast covers, it's totally visible.
they say 450mm if buried
Not deep enough?
I meant the drain is the service
My interpretation of that description is services as being i.e. water (as in pipes), gas, electrical, data, telephone, but certainly not a gulley for water to drain through; am I wrong?
Once over the other side, I was going to run the cable in 20mm galvanised conduit, I suppose I could do that in the drain as well.
Reply to SWA in drain permissable? in the UK Electrical Forum area at ElectriciansForums.net
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
