Discuss SWA in drain permissable? in the UK Electrical Forum area at ElectriciansForums.net
dunno about that, but this thread has me drained emotionally. what about the poor spiders in the duct if the cable is compromised. will 30mA RCD protect them from electrocution?
dunno about uranus, but they can sod of from myanus.
but then a treaty was signed. Klingons are now allies. a bit like the germans on this planet.
A drain is for drainage and not for cable runs as far as I’m concerned.
It’s a bit rough I’d say as I don’t like the idea of water in contact and maybe covering the cable.
Also proximity to other services although not water pipes I wouldn’t do it.
Reply to SWA in drain permissable? in the UK Electrical Forum area at ElectriciansForums.net
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
