Discuss Swimming pool help please in the UK Electrical Forum area at ElectriciansForums.net
Hi, I’m not an electrician- just looking for some advice please - thanks. I’m looking at putting a small swimming pool in an industrial unit to open a swim school. The existing RCD board is currently in zone 1 and has lots of surface mounted cabling serving the existing lights etc, some also in zone 1. The landlord doesn’t want the RCD to be moved. Is it possible to create an enclosure which would put the RCD and associated cabling into a safe zone or even out of the pool room altogether? Thanks for your help.
Thanks, I don’t have plans yet but here’s a photo. The pool would end halfway between the yellow lines and stand 1m high. I’m also concerned about the cabling that you can see going over the ceiling as it would cross the end of the pool, would a suspended ceiling put this in a safe zone? How difficult would it be to move the RCD if it’s not feasible to cover it safely? Very grateful for your help 499648D1-3E58-419D-B07E-DEAD53075644.jpeg
I've seen some requests for advice but this one takes the biscuit. OP your only possible way of seeing if your swimming pool is viable, is to get in a contractor who has a good working knowledge of the regulations regarding swimming pools, it also seems you'll need to make some structural changes, and probably need planning consent or guidance. I've witnessed a local person running a swim school for young kids on the cheap (not suggesting you are) and it was quite frightening the short cuts taken.
I know of a hotel who did something similar to this whereby they had an existing dist board which they constructed a room around to contain it. We had a call that people were receiving small shocks from it when they reset the rcbos which were constantly tripping. The outcome was that over a period of time chemicals in the air had migrated to coat parts of the board internally and externally, you could actually measure voltage across the insulation of the conductors internally.
Thanks Midwest - as I said, just looking for general advice on the RCD. I have already built a pool and currently run a swimming school elsewhere so know what’s involved. Nothing will be done on the cheap, no shortcuts and properly qualified people will be employed to do a proper job. I was just looking for some indication of whether it’s feasible at all to enclose an RCD to safely and legally put it in a different zone as I can’t find any information on this. Thanks
Thanks, that’s useful to know
How was the problem overcome? IP board?
Thanks, I don’t have plans yet but here’s a photo. The pool would end halfway between the yellow lines and stand 1m high. I’m also concerned about the cabling that you can see going over the ceiling as it would cross the end of the pool, would a suspended ceiling put this in a safe zone? How difficult would it be to move the RCD if it’s not feasible to cover it safely? Very grateful for your help View attachment 44571
I think you need to get a local spark or 2 to visit site with you to review this ................ then talk to the landlord .................
and get your cheque book ready!
Ok, not meaning to demean what you're asking. I think swimming pool installations should only be carried out by contractors with a lot of experience & knowledge in this field. I suppose asking opinions on this forum on this subject, could put your mind at rest, but only a complete site visit & investigation, can fully answer your proposals. IMO.
Maybe reading this wrong, but I'm of the impression this is no more than a floor standing kids play pool erected within a frame, i.e. is not a permanent installation requiring structural work, therefore to the landlord it's a standard tenancy. The OP is however right to ensure the electrics are done properly.
Its a swim school apparently; i.e. people paying to have their small charges taught to swim, in a safe & controlled environment, managed by a business.
Reply to Swimming pool help please in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm trying to understand legislation in the UK for using an air pump in conjunction with a swimming pool with regards creating and supplying...
Good morning, So I’m working on an existing 3 phase solar system and the customer wants a way to use the huge mass of exported solar on their...
Hi all, Looking for some tips on supplying my pool equipment (2kw heater, 1hp pump, 1.6kw swim jet, 12w led light) with power. My house has a...
Hi All I'm a professional mobile app developer. Around 12-13 years ago I created a couple of apps for the fire protection / safety industry that...
