- Reaction score
- 356
Hi Guys
Been to look at a job, as follows :
Just wanting to make sure DB I'm coming off of is compliant, as I'll potentially be the last one touching it.
Looking through section 702, seen 702.410.3.4.3(ii) mentions a figure of 20ohms or less if using an electrode to backup PME - that confuses me as thought you couldn't mix the two ! Which leads on to the question of with the Ze of 90ohms, is this ok as its under 200ohms or does it have to be under 20ohms ?
Hopefully this makes sense - sorry its been one of them days.
Cheers Sy ;-)
- Existing Swimming Pool House 20meters away from main house, DB in here on TT set up, Ze = 90ohms.
- Plan is to come off here to supply another outbuilding which is about 15metres away.
Cheers Sy ;-)
