Feb 19, 2024
UK
Electrical Enthusiast (Unqualified Hobbyist etc)
If other, please explain
Hobby
Wiring cooker hood into a switched fuse spur with a 13amp fuse in the spur. The cooker hood is 3amp. Should I swap out the 13amp fuse in the spur with a 3 amp fuse?
Instructions for the hood should tell you what fuse protection is required, but as a general rule a 3A would likely be the best choice.
Reactions: Markyd and DPG
The pics you put up of the consumer unit are all good .....all circuits RCBO protected and as above swap the fuse out for a 3 amp
UK
Hobby
Switched Fuse Spur
UK
Riddirah961,
Markyd,
