Discuss Switching off Light affecting TV signal ! in the UK Electrical Forum area at ElectriciansForums.net
Hi
Strange thing happening with next door Neighbours TV , when they switch off their Kitchen ELV(12V) down lighters x6 the TV screen goes blank for a second then comes back on , it is if the signal goes ( Sky Box ) then comes back on , the TV itself stays on .
I just do not have any idea of what it could be , both on a different circuit .
Anyone got any ideas out there .
cheers
Spike
Hi
Thanks for your reply , will check that out , could that be the case when they are both on different circuits ,and it is not effecting the TV itself , nor the Sky box , both power lights are staying green ! .
cheers
Spike
If this only happens waching SKY , may be a marginal sky Signal Level Quality.( Things growing in front of dish / cable to dish running thru kitchen ?)
Some chanels worst for it than others ?
Do they often get little pauses when it rains.
(May happen with a normal system -If thunder storm -for 30 secs ... The kind of rain wipers struggle with ...but not in rain you can walk to shop in!)
Is this Sky+? If so a brief EM spike from the ELV transformer might be effecting the WiFi signal?
Hi
Thanks for your reply , it is briefly loosing the signal to the tv period , there is nothing obtructing the dish , it comes straight outside through the wall next to tv , then up to the dish .
It is only happening when the kitchen light is switched off ! .
Spike
I was going to say is there a signal booster/amplifier wired into the lighting cct that is somehow causing an issue. But then you said the sky box is connected directly to the LNB anyway. So ignore me please!!
Reply to Switching off Light affecting TV signal ! in the UK Electrical Forum area at ElectriciansForums.net
A friend's partner has an interesting fault, if it is a fault. She sets the shut down timer on the cooker and when the timer goes off (which in...
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
HI everyone I'm getting 255 volts between live and earth natural to live on a live lighting circuit fed from 6amp rcbo , When switch off I'm...
Hi, I am looking to convert a 2 way light into just control by single switch. I have searched and looked for similar questions here, and found a...
