Discuss Sy cable for catering trailer in the UK Electrical Forum area at ElectriciansForums.net
I recently bought a catering trailer and have been advised I need to have it re wired using SY cable.
I can't find much information about this and want to make sure I am going to be getting the right thing done.
Thank you for any replies ?
As @DPG has alluded to:
The supply cable, between the power source and trailer, should be H07RN-F cable.
The internal wiring cable should be flexible cable, same stuff as used in extension leads etc, which uses fine stranded cable. Using standard domestic twin and earth cable is a no no as it has solid strands and is prone to breaking due to vibrations when the vehicle is moving.
Most SY cable in the UK is not suitable for mains applications and doesn't meet current UK wiring standards.
Thank you that's very helpful ?
Reply to Sy cable for catering trailer in the UK Electrical Forum area at ElectriciansForums.net
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
Hi Guys Got a job where property is set up with Honeywell evohome TRVs and controlled via central panel. They're having an extension done with...
Hi Can somebody advise please. I’ve recently bought a food trailer which is wired at 16amp. I’m wanting to run more electrical stuff and I’ve been...
Came into work today with a fairly urgent requirement to install an instant hot water handwash unit in a small commercial kitchenette/servery -...
