Discuss Terminate or lug in the UK Electrical Forum area at ElectriciansForums.net
Good. That's the trouble with braid, it causes dodgy terminations in the long term.
Another solution would be a ferrule bootlace if you can find any of the size you require.
you can get either pin lugs, or bootlace ferules, You can get them for most sizes of cable, but they require crimping. Pin lugs are often used where the cable is too large for the terminals ie, for volt drop reasons. You crimp the lug on and it has a pin which is then inserted into the terminal
Reply to Terminate or lug in the UK Electrical Forum area at ElectriciansForums.net
Hello. New member here. Electrical enthusiast. I am at a friend's house in the Bahamas and decided to look at the load center in the house, which...
Hello - I'm looking to help determine how many connections are allowed on my AC disconnect terminal lugs - Eaton DPU22R. I'm not seeing anything...
I have taken delivery of an undersink water heater. It is fitted with an RCD on the electrical supply cable which terminates with a euro-plug. I...
Just wondering what everyone’s view on this is, if you’re mourning cooker or hob switch in cupboard close by. Would you still terminate into an...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
