A
Andy J
Hello,
I am fitting a Telecom 8 Compact burglar alarm system to a boat.
The boat has both nominal 12v DC supply (ie up to 14.2 v when engine running) and a regulated 12v DC supply for electronics. I dont want to power it with the inverter so 240v is not available.
My original plan was to remove the transformer, connect the nominal 12v supply to the transformer AC input on the PCB- the rectifier diodes should sort out the polarity and I see a voltage stabilizer on the PCB. I would use the small internal 12v battery as normal.
When I removed the transformer I briefly powered it up to check the voltage- it supplies 16 volts to the alarm with approx 13 volts supplied to the internal battery.
My question is whether to supply the alarm via the AC input as above or whether to remove the internal battery and supply the alarm with the regulated 12v supply via the back up battery terminals. I don't see any loss of functionality (apart from the power supply LED not lighting) if powering it via the back up battery.
Any advice appreciated.
Thanks!
Andy
Thanks!
Andy
