Discuss The Future of Fuse boards...? in the UK Electrical Forum area at ElectriciansForums.net
At no time have I advocated a huge cable entry hole, and assumptions are being made constantly. The vast majority of CUs that I replace are spaced off on small battens to facilitate all cables entering through the rear knockout. So in fact there is no hole going into a cavity at all. But when some people are convinced they're right and no one else knows what they're talking about then it's probably a waste of time posting at all.
Out of interest. Do those who object to holes in the back of a DB insist upon installation of an interconnected smoke detection system, prior to upgrade of any domestic board?
Surely early detection of all types of fire would be of much greater importance than the short term containment of one unlikely source of fire.
Regardless of the soundless/ strength of the argument I'm afraid some people argue just for the sake of it.
To my mind this is the ideal method of installation, where practicable. Neat and provides for future repair or addition, without major upheaval.
But it isn't a fire barrier and is the partition a fire compartment boundary. Do you want a spade.
The issue is about leaving a massive hole into a wooden partition.
If some are happy to leave an installation like that, then good on them.
The metal CU should be treated as a form of fire barrier/containment, that being the whole reason for having metal CUs in the first place.
Cutting a hole that size in a wooden partition and leaving it cannot be said to be the work of a decent electrician.
No. The reason was because many of todays highly qualified dipsticks were incapable of installing non metal CU's correctly, causing an increasing danger of domestic CU fires. (in the London area, at least)
The video that sparked this debate was set in a studio as a demonstration of how easily a particular DB could be installed. This was not a wooden partition in someone's home.
If one is to assume the intention was such, then one might wish to consider all possible alternatives - like that posted by @Dave OCD
That is much the preferred way.....and my way, mounted on ply wood with the timber hole filed smooth, smaller than the metal one, negating the need for grommet strip.
Yes, you're correct if fire got into that partition it would be an issue.
A hole that was cut much bigger than was needed.
No it wouldn't be as there should be cavity barriers. The size of entry shouldn't be relevant as there will always be passage around the cables regardless of size.
I could be wrong, and will happily stand corrected, but doesn't BS7671 make reference to holes in a domestic DB solely with regard to finger access in front, bottom or sides and holes larger than 1mm on top, with no reference made about rear?
No reference is made regarding the rear.
I might be wrong, but when 421.1.201 first came out in the BYB, it was about removing the source of fuel for a fire, and nothing to do with containment of a fire.
Has this recently changed?
The intent of Regulation 421.1.201 is considered to be, as far as is reasonably practicable, to contain any fire within the enclosure or cabinet and to minimise the escape of flames.
It is important for the installer to seal all openings into the enclosure or cabinet for cables, conduits, trunking or ducting that remain after the installation of cables - see Figure 6. The intent of the sealing is to ensure that, as far as is reasonably practicable, any fire is contained within the enclosure or cabinet and the escape of flames to the surroundings of the cabinet or enclosure or into conduits trunking or ducting is minimised, as intended by Regulation 421.1.201.
Good workmanship and proper materials must be used, and account must be taken of the manufacturer’s relevant instructions if any.
At no point does that Reguation infer to containing a fire.
Just for information not massively known is that Fire Proof Filing Cabinets are not fire proof if not locked, the expanding air in the event of a fire will open the drawers.
Reply to The Future of Fuse boards...? in the UK Electrical Forum area at ElectriciansForums.net
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
Two questions: 1. I’ve had a bulb in the hall turn black with some white powdery deposits (see photo), whats caused this, guessing i should get...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Apparently Dimplex only guarantee their heaters if they are permanently wired in to a fused outlet. If the socket is only about 600mm from the...
