You're quoting from an interview with someone who helped write BS7671 and not a consensus among the many people involved.
Since one individual espoused this view in 2015, there have been a number of subsequent editions of wiring regulations in which it could have been included. That it hasn't been included might be an indication of others not being in agreement. No matter, it seems odd that such clarification (if that's what we're taking it to be) has been omitted from successive editions - if indeed the IET's position was ever such.
I came across this one from 2019
The penetration of plasterboard and the like and its return to original state, when installing cables, has always been on my mind when carrying out an install. To the extent, I came to fitting intumescent collars around extract fans installed in plasterboard ceilings, and I only ever fitted fire resistant downlights (& noise for that fact), regardless, all trying to observe to 527.2.
I don't see it applies to surface mounted CU's, unless the surface its installed on, is breached. If thats what your suggesting?
EICR today.... mouse came straight in the back.
in other news apparently 1mm tastes the nicest
Did you repremand him / her / whatever, for carrying out an act that could be extemely dangerous to themselves and worse, could lead to C.U's having to have rodent traps built in.
I think hes still in there dead so didnt waste my breath, theres fluff in the middle. I put the lid back on after showing the home owner, all devices are coated in mouse ---- too so ive gone with that board being an operational limitation/fkin biohazard ☣️ scheduled for replacement and worry about it then, and i will be sealing the back up thoroughly
The Future of Fuse boards...?
Dustydazzler,
Mike Johnson,
