Discuss Thermostat Wiring (Honeywell) in the Central Heating Systems area at ElectriciansForums.net
Hi All -
Some advice please on replacing Thermostat and Wiring.
System - Megaflo Water and Heating - Installed 2007.
Original Thermostat - Dial type - Honeywell T6360B
Wire Connections 3
BROWN Terminal 1
BLUE Terminal 2
BLACK Terminal 3
Above Thermostat replaced with Honeywell CM900 (Digital display) Installed 2013 and works fine.
After seeking advice - wired as follows
BROWN Terminal A
BLACK Terminal B
BLUE unconnected
I now wish to replace the CM900 with a Fixed/Wireless Honeywell Y9420H Sundial RF2 Pack
The connection options are as follows.
N
L
1 HW OFF
2 CH OFF
3 HW ON
4 CH ON
The Thermostat is only required for Heating temperature - nothing else.
So the Question is - please -
Of my combination of Blue Black Brown wires - to which terminal should they be connected on the new Sundial
Regards
Martin
Reply to Thermostat Wiring (Honeywell) in the Central Heating Systems area at ElectriciansForums.net
Evening all, Have been asked to wire one of these into a heating system that has no separate control (or valves) for HW & CH. Customer is going...
I would like to replace my ancient Honeywell mechanical thermostat with a Honeywell T3R PROGRAMMABLE THERMOSTAT I have three wires in the old...
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
Hello everyone. I have an older M1M on the board in the furnace it only has four connectors and connections: C (Blue wire) W (White wire) G...
