What you on about ? I said in a earlier post it wasn't seen as mechanical protection, after your post about needing it and a rcd, if cable was less than 50 mm
And if you look, I quoted the same reg number as you, trusting that you'd listed the correct one as I've got better things to do than go and get my book.
Ok will , that wasn't what u answered u just said none were required if in safe zone etc etc , not that it wasn't mechanical protection , we had already "worked" that one out
Pretty slow for a arms member you guys usually have it memorized back to front like the karran
Its not needed in a safe zone, neither is it classed as mechanical protection nor is it earthed.
you said you needed it along with a rcd if less than 50mm, I was clearly pointing out it wouldn't make any difference if you capped the cable or not.
If clearance of 50mm from the surface cannot be achieved capping should be used along with being rcd protected
this is complete drivel....
capping is there to protect cables from the plasterers trowel......
IT IS NOT CONSIDERED MECHANICAL PROTECTION....end of...
i`m just fed up of folk coming in here spouting crap....
