Discuss Three lights control in the Lighting Forum area at ElectriciansForums.net
Marty28k
Hi All, I have a small situation, A = Outside light, B = Porch light, C = Inside Light. I would like to switch A + B together but not C, and then B + C together and not C. Is there a replay or something that would switch between two different control to achieve this ?
There is no simple solution to this.
Standard light switches will not provide the logic you are looking for.
Anything is possible though, it could be done with either a cheep Plc £100
Or it may be possible with some smart switches.
Thanks James, I should have given more detail, its not physical wall switches I’m looking for. The two switches are actually PIR sensors, and I have all wires from all lights and sensors coming into one junction. Will relays achieve this, DPDT maybe ? I need something that will accept a live from either two circuits, but then not pass it back into the other circuit.
It could be done with relays
You will need 1 per sensor
Only light B needs any logic, so you Only need a single pole relay for each sensor.
You need to be mindful of the loading and rating of relay contacts
This is probably beyond the scope of a DIY project, I would suggest you involve a local electrician.
Rcd and other circuit protection needs to be considered also.
Quinetic switches and receivers.
Switches can be configured to receivers in any combination.
S1 can do A & B; S2, B & C; S3, A; S4, B; S5, C.
Or any combination you like.
Solid advice, many thank James!
Reply to Three lights control in the Lighting Forum area at ElectriciansForums.net
I'm considering using several of the remote WiFi switch sets to control a group of five different lights. The existing switches are all grouped...
As the title says. But then I cut off a jst connection off one of the light strips and I can't get them to work together... the one strip is plug...
I have a small Consumer Unit fed from a 6 amp type B mcb to a 6 amp type B,it only feeds 1 light in a bin store . clearly we have no selectivity...
I can't seem to find the right answer for a smart switch installation for a light that has THREE switches. There's conflicting information, and...
