Discuss Three phase inverter for three separate MPAN's? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
CBR600
Morning all
Just looking for some opinions on a situation we have for an installation. Essentially we have a three phase supply coming into a building that has been converted into three dwellings each with their own registered supply meter - one per phase.
So the question is whether (and I can't see why not) we can use a G83/2 tested three phase inverter and then install a separate generation meter for each phase. The customer has no plans to sell, however I guess there might be an issue if he did decided to do so and each dwelling went to a different buyer. They are flats so it could be covered under lease agreements as a common maintenance requirement (similar to a common roof).
I wasn't sure if there was some kind of issue so far as MCS was concerned.
Any thoughts very welcome.
Thanks Andrew
DNO won't like you combining the neutral and earthing arrangements on 3 meters, though I suppose if they're all bonded to the same earthing point / incomer then it's a bit of a moot point.
Reply to Three phase inverter for three separate MPAN's? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I have a scenario where there is a three phase DB in a commercial property where there are mixture of three phase and single phase washing...
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
Hello, We are converting a former office into 10 self-contained flats with kitchens, showers, heaters all electric, no gas. We have been offered a...
Hi folks, I have recently had a 5kW Solis inverter and 15kW/hr of batteries installed. Everything is working fine, but I have some concerns about...
Hello, I'm new to this forum, we are in the process of converting into 12 flats all electric, no gas incl. heating, showers etc. An electrician...
