Discuss Tiltable suitably IP rated GU10 downlight? in the UK Electrical Forum area at ElectriciansForums.net
Electric Magic
Hi
Have a customer who wants to put smart bulbs into tiltable downlights in his bathroom. I've not seen any GU10 tilt downlights that are suitably IP rated for a bathroom, have any of you got any suggestions? Must be a GU10 fitting as he wants to fit smart bulbs.
Sorry. You are correct. I suspect the tilt function means a seal isn't possible.
Reply to Tiltable suitably IP rated GU10 downlight? in the UK Electrical Forum area at ElectriciansForums.net
Hello All Living room will have 12 GU10s. Can anyone recommend any dimmable bulbs that won't flicker and be around 400 lumens each? I've got 4 in...
Hi I wanted some advice regarding which downlights company is better from ancell or forum? I have builders doing works in my house but I wanted...
My customer wants to be able to switch his heat pump (3.5kW) for his swimming pool on and off remotely, he also wants to be able to set times for...
So I just started out recently and I’m struggling with what to price myself at. It’s worth noting I live in the east London area and I’m looking...
Hi All, I have just installed 8x GU10 downlights in our kitchen with a 2 way setup using the 2 cable method, when I turned the light on they are...
