Discuss Timer and contactor in the UK Electrical Forum area at ElectriciansForums.net
We all tread a fine line when giving out advice. I think no matter what anyone says here that the op is going to do this on his own.
Alex,
From your description, it’s a very basic contactor circuit. One, which probably can easily be found if searched for on google or in a basic training manual. There are assumptions made here due to lack of information:
The contactor coil pins, A1 & A2 are connected to the timer, so when the N/O timer contact closes at the required time, the contactor coil will be energised. The two N/O contactor contacts (pins 1&2 and 3&4) will both close when the coil is energised. Therefore live (pin 1) will supply pin 2, so supplying live to the lights. Neutral (pin 3) will close the circuit with pin 4.
Edit:Typing '2 pole contactor circuit' into google revealed plenty of examples...sorry but its really not hard.
I would suggest going to Maplins and buying some 12V DC relays and play with these using a power supply and some lamps. Won’t cost much but will be educational, safer than playing with mains.
You Barribon Buffoon you
Because you don’t know what you’re looking at.
Keep your fingers out of it and get an experienced electrician to teach you how the circuit works.
New posts
Reply to Timer and contactor in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Hello all, I know this is very simple but I would like some advice please. I am installing a new circuit to feed 5 external floodlights. It is...
I'd like to find a timer switch, in a style that looks alright next to decora light switches, to control a bathroom fan. The bathroom fan...
Hi All, Thankyou in advance for your help I have a block of 5 stories with a staircase timer already installed in a 3 wire connection setup. I...
