Discuss Timer and contactor in the UK Electrical Forum area at ElectriciansForums.net
why do you use a contatcor and a timer?
you would normally use a contactor if what you are switching has a high start up current that the OCPD cant cope with or .
a domestic timer can only swich say 20amps max.why do you use a contatcor and a timer?
Send a PM to Paul M or Sintra or Marvo and they'll guide you through the process.how do i get that
I will happily admit that I am in no way an expert with contactors and alike but i feel (and as others have also told me in some cases), the best way to learn is from mistakes and trying it yourself. Trev, who is paul m, sinter and marvo?
......who is paul m, sinter and marvo?
Mate, you're an apprentice. A fairly new one by the sounds of it so you're not an expert in anything yet.I will happily admit that I am in no way an expert with contactors and alike but i feel (and as others have also told me in some cases), the best way to learn is from mistakes and trying it yourself. Trev, who is paul m, sinter and marvo?
the tutor will have broken up for xmas
you use a timer if you want to time something to come on and off at a certain time and you would normally use a contactor if what you are switching has a high start up current that the OCPD cant cope with or what ever you are wanting to use to act as the switch (in this case a timer) cant cope with the load so you use a contactor and a timer to switch the coil so the timer does not take the brunt.
Cracked up more like. How long have you been an apprentice?
What a load of codswallop!
ok then, am seeing him today, can you at least help me understand the wiring of what is already there- i am off for xmas now so won't see any1 until after new year. at the moment, the wiring is as follows: mains live to terminal '1' of contactor and to live on timer, mains neutral to terminal '3' of contactor and to neutral out on timer, terminal '2' on contactor to live of lights, terminal '4' to neutral of lights, A1 of contactor to switch live on timer, and A2 to neutral on timer. the contactor is 2 pole
Reply to Timer and contactor in the UK Electrical Forum area at ElectriciansForums.net
