Discuss Timer and contactor in the UK Electrical Forum area at ElectriciansForums.net
This is electricity you are playing with which has the 'potential' (see what I did there ) to kill or damage property...the best way to learn is not by making mistakes although it is effective.I will happily admit that I am in no way an expert with contactors and alike but i feel (and as others have also told me in some cases), the best way to learn is from mistakes and trying it yourself. Trev, who is paul m, sinter and marvo?
you can't help some people trev, let him break some things and have to call someone in for advice and to fix it.Jamzie FFS! The only advice he needs to listen to is what he has already been told by several members IE. STOP!
He seems determined to do this job despite having been given that advice several times. Imo he's on his own because any more information is going to lull him into a false sense of security
You Barribon Buffoon youAlex,
From your description, it’s a very basic contactor circuit. One, which probably can easily be found if searched for on google or in a basic training manual. There are assumptions made here due to lack of information:
The contactor coil pins, A1 & A2 are connected to the timer, so when the N/O timer contact closes at the required time, the contactor coil will be energised. The two N/O contactor contacts (pins 1&2 and 3&4) will both close when the coil is energised. Therefore live (pin 1) will supply pin 2, so supplying live to the lights. Neutral (pin 3) will close the circuit with pin 4.
Edit:Typing '2 pole contactor circuit' into google revealed plenty of examples...sorry but its really not hard.
I would suggest going to Maplins and buying some 12V DC relays and play with these using a power supply and some lamps. Won’t cost much but will be educational, safer than playing with mains.
Reply to Timer and contactor in the UK Electrical Forum area at ElectriciansForums.net
