Search the forum,
Discuss Timers? in the Electricians' Talk | All Countries area at ElectriciansForums.net
G
gerard
Hi,
I am looking for a timer that will give an output for a period of time. This pulse is triggered by an inductive proxy sensor. The pulse this sensor give is very quick and only lasts 1/10s. I want this pulse to trigger the timer to start
for a set length of time.
What exactly is it your trying to achieve and are voltages already set or are you designing this from scratch?
I understand what you ask but more detail please does this want to only activate timer once or is it a repetitive function ...
A stab in the dark i would look at RS online site and type in the code 329777 this is a multi-function timer and has integral power source to support input from npn/pnp devices, check what its timer function can do and see if it suits your application, if not you could use a plc and write the logic control funtion to you spec' if you are familiar with logic programming.
Thanks guys. I am waiting on a guy who deals with Carlo Gavazzi timers to get back to me. I will have a look at that one Gary and hopefully it will do the job.
Reply to Timers? in the Electricians' Talk | All Countries area at ElectriciansForums.net
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Having to wire around a messed up output for a month or so. Some sort of program corruption is keeping the central lubrication system from...
Hi. I am trying to replace a heating timer with a smart switch. The current timer is the type with a dial on the front and 1 to 24 written on it...
Hello all, I know this is very simple but I would like some advice please. I am installing a new circuit to feed 5 external floodlights. It is...
Hi, I want to wire in a timer switch to a bathroom extractor fan. The extractor fan is currently wired to the light switch or more specifically...
