Discuss Today’s job mainly consists of... in the UK Electrical Forum area at ElectriciansForums.net
Out of interest, did you use a template/pic to position the lights to represent stars, or just drill random holes?
Oh, it looks good as well...
I’ve done quite a few now..
Mainly in steam rooms, what I usually do is split the area up into segments and then randomly drill the same number of holes into each segment.,
Unless the client has a specific pattern such as a certain constellation then random is the best option.
A fiddle when you have an assistant, a challenge on your own..
I also push sleeping up through the holes so I can see them from above and then feed the fibres down
Posh houses over on the island then. Or is that a council semi in Hexthorpe?
Reply to Today’s job mainly consists of... in the UK Electrical Forum area at ElectriciansForums.net
Does anyone know of a free electrical drawing program that I can use to draw neat circuits consisting of a mains supply (fuse board) mains sockets...
I really hope someone can help me. Last July I got an electricity bill showing an enormous rise in my kwh consumption of about 900% from what it...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi all, I just found this forum last night and figured I would post my issue since I can't find much out there with a similar situation. My job...
