Rockingit
Mentor
Had a bit of a scrap on site yesterday with the site foreman after the plumber decided to go drilling underfloor heating pipes about 20mm away from my main rise of CU cables - and there's a lot of them!
I wanted to, and can (still) see no good reason not to, move the plumbing feed over one joist, problem solved. Anyway, all got a bit heated (pun intended) so off I trudge to get the BRB and thrust 528.3 under his nose - at which point he says "that's fine then, we'll just wrap some insulation around your cables"!!!!!
The reason that I put bRb in bold above is because the new wording in bGb is a little different, and does not use the word insulation. Unfortunately it was the BRB I had with me, not the BGB.
"what a plonker" is the most appropriate phrase here. ( i am , of course, referring tom the site foreman )
so you said thats ok, i will just rip out all the cables and fit larger ones as they will now have to be de-rated due to insulation.
TBH, the whole job is a *-up. It's the foreman/site agent/QS that apparently spec'd the heating system design (ground source) and has just got some lad in to fit it. I pointed out to both of them that not only have they created a total nightmare for me in the kitchen (ceiling) both practically and also that there is underfloor heating AND downlights AND a sprinkler system in the same 150mm, but the 'plumber' hasn't even drilled through the joists 'in zone' - that just got a blank look from both of them.
Consequently, there is now 12m of basket running high temperature / heat resistant cable. In a domestic kitchen, on a new build. Crazy.
If you got there first then its up to that plumber to site his pipes away from your cables and that foreman should know that n all.....so this plumbing guy`s a bit of a divvy then?.........
Give your BCO a ring and tell him to get his @rse there and look at those holes. If they get a kicking for it, then they'll take the BRs more seriously in the future.
I have a sneaky suspiscion that the foreman and plumber are related somehow! And plumber is so experienced he is still sporting bum-fluff.
Thing is though I`v mentioned before in this forum about plumbers being thick when it comes to proximities and mutual detremental influences and i said then that what they and us are being taught which to me should be common installation rules seems to be different......
Another part of the joke is that when I started to ask all the electrical questions for this heating, like wiring and zones etc, he didn't know. So I get given the design and spec manual to figure it out myself - and low and behold in it are all the correct instructions for where to drill through joists.
LOL!!! You really DO need to be careful what you put on the internet: I've just done some googling and guess what I found on Bebo.......
Me, Myself, and I: hello, my names ****** im 17 nd live in *****. im easy going nd just like going out wiv m8 nd havin a laugth!! im at collage doing a plumbing apprenteship nd hpe 2 b a plumber soon. i do a lot of bmxing, cuz i lov it nd its a gd sport 2 b into!
plumbers are the bane of most electricians lives the word dense was invented for plumbers any trade happy to spend half it's time up to his elbows in excrement really shouldn't be allowed to make decisions. Personally I'd have finished the job as it was then reported it and failed the installation on the electrical installation certificate i.e I wouldn't have got one
