Discuss Tools for measuring electricity consumption in the Industrial Electrician Talk area at ElectriciansForums.net
N
non-sparky
Anyone with any IT knowledge know of any commercial grade meter for monitoring units consumed that is designed for use in a hosting server rack, ideally with IP access?
Thanks!
Also - message for Shakey, I tried to thank you on the other post but it wouldnt add it to the thread for some reason! Cheers matey!
Thanks!
no problems;)
sorry for being thick but are we talking about kWh meters ?if so you have plenty of options the job im doing currently are installing them on dbs
Thanks!
Elcomponents do them but not IP addressable though they do have a card in them which you download and then can interagate to see Kw, Kva, current , voltage power factor and if the top of the range Harmonics as well.:eek:
Reply to Tools for measuring electricity consumption in the Industrial Electrician Talk area at ElectriciansForums.net
