N
NottinghamRob
Hi
I've recently moved into a new property & have the following issue.
There's an outside light at the back & I can't find the on/off switch for it. There's power to it, as the light comes on if the sensor is tripped, but I want to change it to a normal floodlight & only have it on when I switch it on.
Is there a way that I can try to trace if / where the switch is? I've take the light off the wall, but can't see where it goes from that side. It's at the same height as the cavity between the kitchen ceiling and the 1st floor room above it, so I could get access through the bedroom floor, but I don't really want to start pulling up carpets and floorboards. So, I'm hoping there's some form of gadget that I could buy to try and trace it? Or any other kind of awesome trick.
Rob
Rob
