Discuss Training to be a sparky in the UK Electrical Forum area at ElectriciansForums.net
Which big brown book is that please? The book I'm training from is "Domestic Electrical Installer" Sec 1 Pt A Mod 1 is a red and white book.
I don't want to undermine however your college is trying to teach you. I can't tell you where to find the answer in your text book.
Part 1 is getting at fact that every circuit has an over-current protective device (whether fuse or circuit breaker).
Maybe your text book has examples of frequently used or standard circuits that show what the protective device is?
Failing that this video may help:
Reply to Training to be a sparky in the UK Electrical Forum area at ElectriciansForums.net
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Hi, I'm doing my Level 3 Electrical Install course, and I'm doing distance learning so most of the work is being done by myself with no guidance...
