Discuss Tricky Starter Circuit Question - 2001 Toyota Celica... in the Auto Electrician Forum area at ElectriciansForums.net
MapGuy99
I have an interesting starter circuit issue on a 2001 Toyota Celica (that won't start).
If I have the starter out and have the main positive wire connected, then, run a jumper wire to the solenoid directly, if the starter is grounded to the engine, vehicle fans come on etc. when I set the jumper wire to the positive terminal on the battery.
If I ground the starter directly to the battery, then set the solenoid jumper wire to the positive terminal on the battery, the starter engages and runs as expected.
This seems to be a bit of a mystery. I've tested power at the starter, at the solenoid (when ignition key is set to start) and the power is over 12v. So, it appears the ignition circuit is sending power down there when the key is turned. But the starter fails to do anything. I've also confirmed there is full power at the main power terminal on the starter.
Any suggestions?
Thanks in advance,
MG
Reply to Tricky Starter Circuit Question - 2001 Toyota Celica... in the Auto Electrician Forum area at ElectriciansForums.net
Hi guys, im currently trying to start my new big block chev in a chevelle but having issues.. im a full novice on electrics so be gentle ! The...
Good evening all Ive got an old truck 1990 that has always had intermittent starting issues whilst ive owned it.. As far as i am aware the...
Hello Starter turns over engine but wants to re-engage when running. Trying to establish if wiring, solenoid or starter fault. I understand system...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hello and Happy New Year. It's not starting too well for me, excuse pun. Since Friday December 16th, The 2.4l Duratorq diesel won't start...
