Discuss TT systems and eicrs ? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Evening all
If you were to carry out an eicr and you came across a TT system what is the procedure and required tests....I can see how you would get a Ze reading etc but how in an existing installation do you get the earth road resistance RA....as I can imagine that rods might be next to concrete or anything and so the 3 lead method and spacing out would seenm impossible
Cheers for any answers as this is something that wasn't really touched on in college and I've never come accross tt systems in the working environment ?
Reply to TT systems and eicrs ? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
Carrying out a EICR in a commercial setting. In the main intake room the DNO supply comes in and it states clearly this is a PME system. 5 years...
Hi All Happy new year to all! First post but long timer lurker, so thanks for all the previous help! Just wanted to clarify something I have...
Doing a lot of EICRs at the moment and have came across what I'm sure is a common enough problem. In an off grid rural cottage I have a TT system...
