Discuss Twin and earth clips that don't clip in the UK Electrical Forum area at ElectriciansForums.net
If you mean the cable pops out of the clip once it's hit back, chances are you are using crappy clips. The best ones I have found are Thorsman. They have the curled return to the clip that holds the cable nicely. Thorsman have now been absorbed by Schneider so look for the green and white packaging, but not the boxes the trade tubs. I find that Schneider clips in boxes are Tower brand while the Schneider trade tubs are Thorsman brand. Tower are the crappy ones that don't hold the cable properly.
All this depends on whether or not this is what your original question is about.
tower are not too bad, i think it varies on the cable brand you use, different cable has different sized insulation
only read this coz i'm bored. geordiland's answer to bill & ben the flowerpot men ( ant & dec) on the bloody telly again.
certainly hope so. i do know that this is closer to the true geordie.
Reply to Twin and earth clips that don't clip in the UK Electrical Forum area at ElectriciansForums.net
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Is anyone aware of any galv trunking that is smaller than 50x50. I'm drawing a blank online. I've taken over a job that's used 16mm twin and earth...
hi....im running cable for a split type 1.5 hp aircon....i have a roll of english 2.5 twin & earth, is this ok for the job? im running it to the...
Hi, I have a book on domestic wiring which says that everywhere there is a change in current carrying capacity along a circuit there must be some...
