A
AA410
Hi there ideas or alternatives to twin and earth clips that don't clip please
Discuss Twin and earth clips that don't clip in the UK Electrical Forum area at ElectriciansForums.net
Twin & earth clips that do clip.
forget the screw and use nail in plugTaking out the nail and using a screw and a rawl plug.
now you're assuming that the OP is a joiner.Don't bother with clips just nail through the cable
tower are not too bad, i think it varies on the cable brand you use, different cable has different sized insulationIf you mean the cable pops out of the clip once it's hit back, chances are you are using crappy clips. The best ones I have found are Thorsman. They have the curled return to the clip that holds the cable nicely. Thorsman have now been absorbed by Schneider so look for the green and white packaging, but not the boxes the trade tubs. I find that Schneider clips in boxes are Tower brand while the Schneider trade tubs are Thorsman brand. Tower are the crappy ones that don't hold the cable properly.
All this depends on whether or not this is what your original question is about.
GASP!I'm gonna throw a wild one out there...... trunking ?
GASP!
Can it be used as a CPC?
Sticky pads and cable ties? Silicone? Nomore nails?
Gaffer Tape ... the Roadies best friend. Guaranteed to stick your Granny to the ceiling in the middle of a typhoon.
Is it just me or is this image not working
They are not representative of the true Geordie male.T
Or if you mean you can't get them to bang in use these
Tower 55PP1 20mm Grey pin plug (use 5mm drill) - Edwardes
Hell no!I'd have to watch Geordie shore for the proper fellas I take it ?
Seems an expensive way to fix a nail in clip
you do realise red wall plugs work100 Pin Plugs For Fixing Cable Clips Into Hard Surface | eBay
they are well handy in some situations.
Would not a wooden dowel be the best fix for a clip ? Never used those pin clips mind you.
Wood battens across the walls with the cable buckle clipped.
THIS is what you want! -->>>> 1 BOX 100 1 1/2" x 14 GENUINE VINTAGE RAWLPLUG FIBRE WALL PLUGS RAWL SCREWS | eBay
But then you also need a rawl tool
Ok .... here you go -->>>>> VINTAGE RAWLPLUG 4 IN 1 TOOL WITH ORIGINAL PLASTIC WALLET | eBay
Are you having a clear out?
Reply to Twin and earth clips that don't clip in the UK Electrical Forum area at ElectriciansForums.net
