Love Manchester, where it all goes on , better then scousapool..
Not knocking it , but their seams to be a lot of john bishops .
and if not,remember as long as you are near to conglomerate coffee chain,there will be a nervous,poorly trained first-aider to be embarrassed in to an attempt at stemming your flowing arterial knife wound,as the teenage assailant,makes off with your empty Gluwein mug...
Use talcum powder.My pal who was assisting me with feeding t&e through conduit sprayed them with a silicone spray from skewfax, and all went well until my CK strippers refused to grip the insulation...
Looks like maybe the conduit isn't big enough for the cables you are using, judging from your description OPUse talcum powder.
At a pushYou should be able to get a 1.5 and 2.5 T&E through a straight conduit run of 20mm conduit.
Some of the questions in this forum are obviously from the unskilled. WHY are they carrying out electrical works?As conduit is designed for singles cables it's not intended to be restricted to only one cable. But you haven't stated what it is you're trying to achieve.
The PVC sheath is not as thick as it used to be I have noticed the difference over the years.At a push
Still a bit of a push Ant, imo anyway.The PVC sheath is not as thick as it used to be I have noticed the difference over the years.
