Discuss two machines one supply in the UK Electrical Forum area at ElectriciansForums.net
Doomed
Client has 2 three phase machines, both with 5 pin 16A plugs.
He only has the one supply (2.5mm SWA) and wanted to run both machines from that.
Without fitting a sub board is there some form of rotary switch that will power one or the other, but never both at the same time.
It would be awkward and probably too expensive to upgrade the supply and fit a proper sub dis board.
And before anyone asks, he has become fed up of having to unplug one machine to use the other, he uses one straight after the other in a manufacturing process 'a lot of times' in a day.
Used to Use Klockner Moeller chnageover switches alot for this type of installation tohugh i'm sure there are many other makes that do the same thing.
Cant remember part numbers but definitely the right sort of switches out there for this,try Klockner Moellar/ Telemecanique/ Shnieder to name afew brands (may have got the spellings wrong)
Try here for starters:
Change Over Switches | MeteorElectrical.com
Just a thought here,
Just because both machines are on 16A plugs does not mean they are going to pull 16A each, what is the ratings of the machines ?
Reply to two machines one supply in the UK Electrical Forum area at ElectriciansForums.net
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
I have a scenario where there is a three phase DB in a commercial property where there are mixture of three phase and single phase washing...
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
We are refurbishing an empty commercial building at the minute and I don't do commercial stuff day in day out so not entirely clued up on...
