Discuss Unable To Reset GFCI in the DIY Electrical Advice area at ElectriciansForums.net
wpollock
Upfront disclosure, I am a DIY homeowner with basic knowledge of electrical safety.
Here is my issue:
Type GFCI Outlet- Eaton TR Installed mid to late 2020
Corresponding Breaker in Main Panel- Square D 20 Amp in number 20 position
The main breaker is designated as Bath GFCI and I know for a fact that the GFCI protects two outlets in a hall bath, one outlet in a powder room, three outlets in the master bath and one outlet in a utility room. I assume all outlets protected by the GFCI are run in a series that starts at the GFCI and ends at one of the protected outlets. The one farthest from the GFCI in distance is the one behind the master bath toilet.
I plugged a 110 volt ac Vornado heater into the protected outlet located behind my master bath toilet and the heater turned on and operated normally. However, roughly one hour later I returned to find the heater off and the GFCI tripped. The corresponding main panel breaker was not tripped. The GFCI has two indicator lights, one orange and I assume the other red. The orange light is lit and I am unable to reset the GFCI. The GFCI user pamphlet says the GFCI is bad if the orange light continuously blinks which it does not. The red seen on the main breaker is due to the angle of the picture when I took it. I have unplugged everything from any receptacle known to be protected by this GFCI, tripped and reset the main breaker associated with it and am still unable to reset the GFCI. Any ideas what my problem could be are appreciated. Pictures attached of the currently installed GFCI, the corresponding main panel breaker and one I am considering using to replace if it is possible the current one has gone out.
Here is my issue:
My friend it sounds like it just needs replacing. It’s been in service for 2 years and they are not very reliable because I have purchased some and too it to my job and sometimes they are bad straight out of the box
Make sure nothing else is plugged into the circuit and then try to reset the GFCI.
Reply to Unable To Reset GFCI in the DIY Electrical Advice area at ElectriciansForums.net
Any help or advice. I'm not able to trip my gfci with my plug in tester. IfI push the test button the gcfi will trip but the red light won't turn...
Hi, My hot tub keeps tripping after 12 years of use. I'm thinking it's the GFCI gone bad. Unfortunately it's a CH 2 pole 50 amp (GFTCB250) and...
I’m installing a gfci outlet inline with the power that goes to my well pressure switch. The GFCI will be to power the heat tape on the well...
I have a small power washer with a two-wire cord and GFCI plug. My outdoor and garage receptacles are on a "house GFCI" circuit, wired in series...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
