Discuss Underfloor heating thermostats in the UK Electrical Forum area at ElectriciansForums.net
Gavin John Hyde
Patron
I tend to run a mile from underfloor heating as its a pain in the backside to put right if it goes wrong.
Got a regular customer whose old manual thermostat has died, power goes to it, but nothing else, its dead. Tested resistance of the heat mat and the values pretty much same as paperwork when installed.
Being a basic manual one, from my limited UFH experience then any other manual one should work? after all it only has Live and Neutral from supply, CPC terminates on back. then live out to mat, neutral out to mat, with 2 wires for the sensor down through conduit.
Anybody got any thoughts?
pic shows current one. I shall be hoping to replace with another one of same ilk. albeit newer.
I can't say for certain as I don't have much experience with UFH, but I suspect the temperature sensing element and the thermostat itself may need to be matched.
There are a few methods of sensing temperature electronically, some purely resistive (like thermistors - which have different temperature curves and values) and some semiconductor based which operate in an entirely different way.
I think that is why a lot of the thermostats available come with the probe/thermal sensor aswell, to ensure compatibility. It relies on the original install to have installed a conduit or pipe run to be able to slide it down or into the floor..
Electrically speaking it is straight forward, just a nightmare to fix as it can mean ripping the floor up!
or buy a stat that is capable of sensing room temp. this would normally be set lower than you'd expect as ufh is generally to keep your tootsies warm, not heat a room.
Reply to Underfloor heating thermostats in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Got to look at a job where the builder has cut through the underfloor heating mat and it’s gone right through the heated cable. Not...
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
m having a bit of an issue that is proving difficult to resolve. For 2 years I have been having no problems with my setup. I have a 3 zone house...
I'm after some advice please, I have carbon mat underfloor heating throughout my bungalow, each room has its own thermostat and are fed via a...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
