DL electrician
Am looking for a reputable underfloor heating company/supplier.
Client wants to use heat mats and wants a decent system. It's a small ish kitchen, say 7msq. Going to be tiled.
Loads over the Internet, but not much can be done when it's tiled!
Thanks in advance.
Google Ambient UFH. I've had four kits from them now and never had any problems and they will give you all the advice your after. One was fitted last week and now I just need to go and connect it up!
Warm up is great stuff. I fitted some stuff from bathstore once that a client supplied and it was horrible
You want either Warm up or Heatmat, both very good and well established, dont forget for a great job install 6/10mm2 themal insulation board underneath the heating, also get the 200w per 2 meter and not 150w per 2 meter, the latter wont heat properly.
It depends what you want it for and if it's going to be the primary heating of a particular room. The one I have just done was 15m sq at 150w per sqm with 10mm of insulation boards.
Thanks for your input guys...
It's mainly to take the chill from the tiles, especially when the weathers like this!
I'll check those out!
