This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
T
theone
IMG_0104.gifAny Idea?
Hi
Just looking for some adive/help. Please see attached photo.
The two elements have just been changed and still getting very little hot water and not as hot as it used to be. The elements are on max temp.
any idea/help would be great.
Thanks again for any info.
clamp the cable and see what current is being drawn????? and if 3kw you should be getting 18 ohms roughly
- - - Updated - - -
other than that i dont know, maybe hot tap running constantly somewhere
- - - Updated - - -
Thanks ill give that a go and if there is not 3kw any idea on what may be the problem?
a stat of some sort not allowing to heat up, functioning coreectly, but as you say they new... hard to say without being there and im not in game long enough to help any further , just be guessing even more
- - - Updated - - -
maybe somone else can help more..
Is it water in the cylinder not hot or water at the tap not hot?
When was the new blending valve fitted -- white capped valve in the middle of the photo?
