Discuss Upstairs lighting MCB not working? in the UK Electrical Forum area at ElectriciansForums.net
P
Paul Smith
Hi Guys
I went to change an extractor fan in the bathroom today which runs off the light switch. I thought I'd isolate the power upstairs using the upstairs lighting MCB. I always double check there is no power there by switching on the lights and using my fluke to test for voltage and all the light still work? Would you say I have a defective MCB on the main board?
Cheers
Paul
might be the bathroom lighting is on a different MCB. try the other 6A MCBs.
I did the electricians course about 5 years ago but never followed it through to a proper job. I've forgotten most of the stuff now :-( Just by chance that I've found a fault I think when I went to Isolate the upstairs lighting. The MCB is labelled upstairs lighting but it all still works when I tripped it?? I'm an Avionics engineer by trade so I'm fully competent with continuity, voltage, insulation resistance etc..
I tried the other MCB's but nothing is switching off the upstairs ring main....
There is only one RCB on the board. This has not tripped. The board is a 16th edition.
Thanks for the replies.
Paul
unless there is a cross connection between circuits, 1 of the MCBs must turn off the power to the lights. does turning off the main switch kill them?
Hi Telectrix
I haven't flicked the main switch yet (Mrs Smith is watching TV.) However I have 240v at the upstairs lighting MCB and 0V when you trip that switch so that would confirm the MCB is working. I'll have to wait till she goes to bed or I'll be in trouble :-(
if you have 0V, how come the lights still work , as your previous post?
OK I have figured it out sort of. The upstairs lights run of the smoke alarm MCB and vice versa. Someone can't label properly :-( That's easily remedied. You're right Des 56..
The bathroom lights and fan must run off a different MCB.
The only RCD I have on the board appears to protect the socket ring mains..
Even in new builds, it is not uncommon to find circuits mis-labelled, e.g. a couple of circuits with the labels swapped. Obviously whoever signs the work off doesn't check!
Reply to Upstairs lighting MCB not working? in the UK Electrical Forum area at ElectriciansForums.net
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
Hi I know I have to do more testing but I just want to see if there is something I’m missing. Customer said light fitting in the loft was...
Hi folks, Quick query for this still practicing regarding bill payment for a job not complete. My partner recently employed an electrician to do...
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
