T
teejay
Hello can anybody offer some advise. 3 phase lathe being moved in factory workshop . I have to extend 10mm singles in the trunking, upon investigation found the 10mm earthing conductor for the lathe has been taken from the metal trunking. I will probably rewire the earth back to the d.b. as trunking may in time become disconnected therefore losing earth continuity to the lathe, am I doing the right thing or can I rely on the trunking as being a reliable means of earthing.
if the trunking is electrically continuous, i.e. measure resistance ( low ohms ) from DB to point of utilisation. then it's OK to use . however, it's no detriment to add an additional cable cpc, and would possibly reduce your R1+R2,
Galv trunking is permitted for use as a protective conductor
543.2.2 (vi) refers.
You would need to ensure it's suitability for use though, joints etc.
Yeah just check your readings, I always put bonding links on trunking when I use it for earth, however I don't think theres any requirement to do so, so if they are not in place I would just check all screws on joiners etc.
Tis very common in industrial situation, and perfectly acceptable too, often giving very good readings.
using metal trunking as earth
Australia
teejay,
teejay,
