Discuss Veritas R8 Troubleshooting in the Electrical Forum area at ElectriciansForums.net
Jayjay1
Hi all,
Just an old problem I wonder if anyone can advise me on.
First of all I do not have the engineers code to my alarm, I have read suggestions it can be reset by powering down but it may be locked. How do I know if it is locked or not? I can't find info on that in the manual or anywhere online. When I purchased the property an engineer came out and changed my user code and entry/exit times. I asked him to return a few months later (same guy) to extend the times and he came and tried for a while but told me he couldn't do this and the system was too old. This is what makes me think it is locked.
I have a problem with my old veritas alarm - essentially it keeps going off and I am unsure what the fault is. The zone includes my front door and back door and I think 2 window sensors (texecom impaq). I think the problem is with one of the sensors - the green comfort light does not blink as it should at times and sometimes lights up orange without touching it. Is there some way I can just disconnect this so it does not form part of the system? What is the best way of finding the culprit?
The manual also mentions some things you can do without the engineers code, like change your user code or perform a walk test etc. When I enter my user code and press prog it does a single beep and the zones do not light up as it suggests in the manual.
telectrix
Mentor
difficult to assess without a site visit. some members are more familiar with texecom than i am, so you may get a more positive response after beer time.
PEG
Mentor
Hi,you may find the alarm dudes are a tad reticent,in case you are in the property,tapping away on their laptop...waiting for them to come back off their holidays...;)
Reply to Veritas R8 Troubleshooting in the Electrical Forum area at ElectriciansForums.net
Hi, moved into a house with Veritas R8. One PIR is faulty, stopping alarm getting set. Don't have engineer codes (tried 1234, 4321 etc). How can I...
My Veritas R8 Excel panel recently developed a power fault and I have replaced the entire unit and reprogrammed it. I can part set the alarm when...
Morning Guys Anyone else get fed up with plumbers/ builders supplying UFH (wet & electric) gear and it's the cheapest load of [email protected] !! Had enough...
Hi, Our alarm always has a zone open whenever we set it. The zone consists of two door sensors and three shockguards. Is there a way to work out...
Hi I’ve recently installed a texecom veritus excel alarm system but having an issue with the sounder not going off when triggered by the pir I’ve...
New Posts (Please Reply)
