Discuss Very Hi ZS Reading on TT system? any advice in the Australia area at ElectriciansForums.net
We i am trying to understand, I have carried out a good few ZS test and up until now they were all fine results... Your right I dont know it all, I want to learn.. I am trying ti understand these results... thats why I have come on to this forum..
basically you have a means of earthing here that can have a max of 1667 ohms....but a Ze of over 200 ohms may not be stable...in worst case conditions.....you aint gonna get a Zs of of any final circuits here anything like a tn system and you may also find that you are relying on an RCD soley for fault protection....
We never stop learning and NO-ONE knows it all. That said you are being employed by a customer for your knowledge and ability to carry out a safe and reliable installation and as such you need to know what you are doing. You clearly have a basic knowlege of the need to test but no understanding of how to interpret the results.
As a matter of interest you believed that the readings for Zs were above those quoted in the on site guide, what did you do about it? as your belief was it was unsafe. I bet it was left connected until you could get on this forum to find out what to do.
Not meaning to beat the same old drum or insult you but I hazard a guess that you have recently joined a Part P scheme after completing a short course.
srl-8: None of us know it all & that's not what wer'e saying, but at the end of the Day the Public are paying for you to go into their property & carry out a Board change or whatever & expecting you to be fully competent at what your doing. From your post it appears that although you seem to understand basic testing, you don't understand the results you get & what to do about them. Not to put too fine a point on it but you could be risking peoples Lives & Property.
yes and if that is the case (a short part p course)...then it need addressing as were talking disconnection times here and these "courses" really should be covering this......
They should, but in all honesty 5 weeks does not give you any time to learn the theory behind how we get the results we get and the reason for the tests being required. I have no doubt that testing is briefly covered but it takes time to teach it to people who in many cases have had no or very little past electrical experience.
There is no substitute to working with an experienced electrician and learning the ropes over time combined with theory based learning in college before going out alone.
Now what did they call that type of training that had worked for years and was proven to produce (mostly knowlegable) sparks and weeded out the dead wood and chancers (answers on a post card please)
some info for you all.
1) yes I am part P
2) the property is my own, no customer life or money at stake
3) I came here looking for advice and help.
4) system left unconnected until i solve the problem.
So, who wants to answer my question straight? Please..
ZE reading 187ohm
I can determine ZS by enquiry, ZE +R1 +R2 = ZS
However, i tried to test and measure ZS at the end of the circuit and got these high figures of 2.6 2.5 etc etc...
again, any ideas on how to solve this issue???
1) yes I am part P
ZE reading 187ohm
It's Ra, not Ze on a TT system.
Is your TT system protected by an RCD as it should be with that Ra value?
What is the rating of the RCD?
ZE was 187
the system is protected by a 30ma RCD from the main house, and the new board is also protected by a 30 ma RCD.
Reply to Very Hi ZS Reading on TT system? any advice in the Australia area at ElectriciansForums.net
Doing a lot of EICRs at the moment and have came across what I'm sure is a common enough problem. In an off grid rural cottage I have a TT system...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Hi All Let me start by saying I have my 2365 level 3 but never worked in the industry so my knowledge is limited. My partner and I recently...
Hi all, new to posting but been reading for years. I inherited a house from my grandmother who passed in 2021, I intend to renovate and rent out...
10K
Hi.... First time I've posted here. I own a property which is rented out. Recently the Gas Oven failed a gas safety test and the Gas Engineers...
