Discuss Vfd for well pump in the DIY Electrical Advice area at ElectriciansForums.net
It could be that you only require to run the motor at a fixed speed to produce your 60psi constant pressure, however, if the process is variable and it needs to tune itself. THe higher end Rockwell drives have built in PID functions that can use the 4-20mA signal from the pressure transmitter to ajust it's own speed accordingly.
I’m want to use a Allen Bradley 22-A4P2N113 Powerfex
That particular model doesnt have PID capabilities.
I would install it, an using the dial on the front, see if a 60psi constant pressure is feasible without PID control.
If it isnt, then an Allen Bradley 820 plc will be the cheapest way to introduce PID control. An the software for it is free.
Ok thanks for all the help. Appreciate it
Reply to Vfd for well pump in the DIY Electrical Advice area at ElectriciansForums.net
Good evening all, I’m currently part way through my apprenticeship and we are working on IB, IN, IZ and IT and volt drop today. And it got me...
Hi Everyone, Has anyone ever encountered an undersized start capacitor (from manufacture) for a single phase pump??? I would like to integrate...
Hi Guys, just looking for a bit of advise. I am booked up to go on 2391-52 soon, and was looking at using my own tester, Megger1552. It is all...
Good morning, So I’m working on an existing 3 phase solar system and the customer wants a way to use the huge mass of exported solar on their...
Hi, We are renting and have a electric shower downstairs (extension) - a 9.5kW Triton T80Z fast-fit electric shower as well as a combi boiler...
4K
