Very conductive I hear. Does me head in when you get a thread that makes you think and is interesting, that then gets left up in the air
Is Purple really not going to let us know how it ended? I'd really like to know? Theres been almost 5000 views!! Come on Purple!!
" The purpose of connecting the customer's system to ground is to limit the voltage that may develop if high voltage conductors fall down onto lower-voltage conductors which are usually mounted lower to the ground, or if a failure occurs within a distribution transformer. If all conductive objects are bonded to the same earth grounding system, the risk of electric shock is minimized. However, multiple connections between the utility ground and customer ground can lead to stray voltage problems; customer piping, swimming pools or other equipment may develop objectionable voltages. These problems may be difficult to resolve since they often originate from places other than the customer's premises. "
Just found this on the net,
It may help your quest, although it does say it may be difficult to resolve lol.
I'm keen to hear your findings .
May you get to the source my friend.
I've had same with 'tingly taps' post a while ago, finishing with SEB digging hole and repairing joint, the end.......no, after this was called in again as fault returned. Bloody macerator was faulty. Have you got one in the system?
