Love them, the halicons (spelling?) are cheaper at 7p for 2 pole and 9p for 4 pole so I usually use them but they are IMO harder to get out without snapping off the wire inside.
Thought they wer designed as a perm connection ? ...ie not designed to be pulled out of the terminal ( ive never used them mind, just what ive assumed)
Wago 2 pole get for 10p each and 4 pole 11p each delivered.
When you need to loop in/out in the back box they are a life saver.
Also extending lighting circuits, wagos and a choc box, easy
From Wagobox.......
Simply pushing the stripped conductor into the connector makes the connection. The transparent housing provides a visible indication that the conductor is secure. There is a test point in the base of the housing. To remove the connector simply pull on the conductor whilst twisting the connector block left and right. The connector can then be reused.
lol, didn work ,.....the wago lever connectors ,...n u can get a 'cage carrier ' for mounting them on DIN rails
I like wago's save so much time especially the din rail mount type the is a pic on a that shows wago push fit din rail types its on extending cables for new consumer unit i think likes been said ask for a sample pack or visit the stand at Elex in coventry
Just got the sample pack through, well impressed, simple, qiuck, secure, insulated, easy,...along with the wago box that including cable clamps and placement gaps for the blocks, easy fit fixing bracket thing,
Well impressed fair play,
wago from now on :-D
daiplayer,
MDJ,
