The symbol MF is for maintenance-free 'accessories'.
Look at the (v) above that. "Joints and connections made in equipment by the manufacturer of the product and not intended to be inspected or maintained"
Love them, the halicons (spelling?) are cheaper at 7p for 2 pole and 9p for 4 pole so I usually use them but they are IMO harder to get out without snapping off the wire inside.
any one know where i get these?
Sent from my GT-S5830 using Tapatalk
Got a couple of free samples of hellermanns version (helacon) from CEF the other day, will post when ive tried them
I am talking about ''Official'' recognition, Not a bit of salesman patter!! They can say what they like, and often do, but it doesn't make the connectors officially recognised as ''Maintenance Free''....
Engineer54 & Topquark, you were both right & I apologise for my misleading statement earlier in this post.....
The 'maintenance free' approval has not yet been given, as the box doesn't carry the MF stamp.... it does seem as if it is about a paperwork exercise to gain approval rather than any shortfalls in the product but this was the official reply from WAGO...
Within IET's new amendments of the BS 7671 they do recognise "Maintenance Free", we are in the process of getting all the relevant paper work together to ensure that WAGO and Connexbox comply with the new amendments.
BS7671 526.3 (vi) "Equipment complying with BS5733 for a maintenance free accessory and marked with the MF symbol and installed in accordance with the manufacturers instructions."
"Equipment" from the above statement means the enclosure and the connectors together, the enclosure will show the MF symbol not the connectors.
We are still in talks with Connecbox and once we have further information regarding this, we will let you know.
This can also be seen on the Hager (Ashley) junction box (J803 and J804), which is maintenance free and contains our 862 Series connector.
If there are any updates on this, I'll post them up as I get them,
Regards
So how do you guys interpret 526.3 (v) Joints and connections made in equipment by the manufacturer of the product and not intended to be inspected or maintained
To me that says the joint or connections made in equipment by the manufacturer (the Wago connectors) and not intended to be inspected or maintained (Wago don't intend for the connectors to be inspected or maintained)
The real problem is with WAGOBOX. The wording in BS7671 is in legal speak so they have been avoiding this issue by arguing semantics. However, BS 5733 uses plain english and states:
11.1 Accessories shall be so constructed and enclosed that thereis protection against accidental contact with live parts when theaccessories are correctly assembled or mounted and connected fortheir intended purpose. Live parts shall not be accessible without theuse of a tool even after the removal of parts which can be removed​
without the use of a tool.
(if you think this is more onerous than BS7671
412.2.2; 412.2.2.1; 412.2.2.3416.2.1, 416.2.2; 416.2.4 - i would like to hear your reasons why.)
As the WAGOBOX can be opened without a tool or a key and the cables can be removed without a tool or a key they can not say it complies with MF and BS5733.
The best option is to use WAGO connectors but with an enclosure that does comply!
I think the "line" boxes would comply as you can fit a zip tie to "lock" them.
Only my opinion but I cant take them off without a tool - cutters!
Screwits.....surely they cant be advocating the use of these now.....they're off of the 30's!:crazy:
daiplayer,
MDJ,
