G
Geoff Clark1
Hi. I'm new to this. A question about garden lighting. I need to install aprox 20no walkover lights along the edge of a new patio, aprox 15m accross by 4m. Lawn in front of patio about same size. Wondering whether to install L/V, LED or mains. Also I've always used pratley boxes. Are there any alternatives? Any advice would be appreciated.
Thanks,
Geoff
Hi Geoff. When you say you are new to this can you let us know your skill levels and qualifications. This way it is easier for advice to be given.
they are usually of the `plug & play` type.....
they will all go back to a common manifold.....this is/should be suitably IP rated....and will then come off an outside supply...again this should be suitably IP rated....
Hi Sintra. Thanks for prompt response. I'm a one man band NICEIC approved. Did the test & inspec 2391. 38yrs old. 20yrs in the game, 7yrs on my own. Done mainly indoor domestic, some com & indus. Some outdoor stuff, brick lights & directional spot lights on spikes mainly.
Geoff
If you are installing new lights then you should comply with part L of the building regulations. I would be attempting to have all joints above ground if possible (and accessible) and suitably IP rated.
Walkover lights usually have fitted cabling so take that to your supply manifold.
Hi Richard. Thanks for the help. The joints need to be beneath ground. I'll look in to part L.
Geoff
