Dizzy_Maskell
Guys not used before but looking for some good quality easy to fit reliable Brick style LED for new wall I'm having built.
Fully qualified spark just want a make and place to buy from don't want to break 2 years down the line prepared to pay bit more?
Thanks guys
I will keep an eye on this thread as I have been looking for the same for a couple of years. I have a job to replace 4 that have just rotted away. I asked the same question some while ago and was laughed down. I will probably replace the ones I need with some good quality circular bulkheads that will cover the brick-sized holes.
God luck.
God luck.
https://www.tlc-direct.co.uk/Main_Index/Lighting_External_Index/LED_Marker_Light_Kits/index.html
TLC are a good supplier and don't sell crap, I buy loads from them. There is a brick size led on the page above.
Now I am not sure if I am after the same thing as the o/p, I need to replace some brick-sized lights that were built into 3 walls as they were built.
WHOOPS, I didn't scroll down the page. See what you mean now, will look into ordering 4.
Thanks.
I refuse to fit brick lights anymore as they are more trouble than they are worth imo.
If someone can point out one that is IP67 or better I may change my mind. I've not found one. Most people want them fitting in flower bed retaining walls or steps and the water finds its way into IP44 tat.
