Discuss Wall light cable not long enough in the UK Electrical Forum area at ElectriciansForums.net
rlink0216
Hi I am changing a wall light and after removing the wall has crumbled away and the cable is too short to connect to the new light fitting. Please could you advise if connecting the new fitting with a choc block will be safe. Any help appreciated.
Russell
if the choc block will fitinside the base of the new fitting without putting strain on the cable/s then OK. you may needt o chip out some of that filler. dif-tor heh smusma (live long and prosper)
i find thart in that situation, unclip the choc block that is part of the fitting. connect your L,N,E into the block . ditch the other choc block. then fix fitting.
definitely NOT. any extension to cable/s must be crimped/soldered, and insulated with heat shrink sleeving, or wago connectors in a wago box, maintenance free.
also, 1 of those red conductors seems to have insulation damage. an electrician could fit your light to the existing cables over the hole in an hour. just have a bit of decoration to repair
Ok thanks I don’t think I can fit a light here as there is no clearance around the short cable to attach it to the light fitting
I think the original light fitting wasn’t fit to regulations as it was just connected with a choc block. This is a very old house circa 1800s.
Reply to Wall light cable not long enough in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
For various reasons out of my control, we have wound up in a situation where we have 1.5mm SWA cables buried in these pillars and exiting out of...
7K
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
Hi My Kitchen has never had a cooker hood installed. Where the new hood is going to be situated is some distance from any of the outlets in the...
