Discuss Wall light with no earth connection in the DIY Electrical Advice area at ElectriciansForums.net
Trying to wire up a Dar wall light but see no way to connect the earth as the plastic terminal only has two connections ( L/N) ?
possibly its a class II product. Double insulated. Square within a square symbol.
You just have to make the earth wire safe. (dont cut it off, because any future light fitting may need it.
Make sure you follow the fitting instructions, to maintain the double insulation. It might come with a near useless little black box for the connections that are an absolute PITA to deal with. You need to use this box, and any cable clamps.
Thanks yes I think you’re right , I’ve just seen the square within the square so presuming it’s double insulated .. thanks !
Reply to Wall light with no earth connection in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
I have a spa bath, with lights, pump and lights are straight plugged into mains with 2C+E for pump, there is an additional ground wire on metal...
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
