Discuss Water Tank Heater Temperature Control in the UK Electrical Forum area at ElectriciansForums.net
Can't see it has any thermostatic control built in? doesn't mention it in the link.
So maybe 80c is what it just reaches before the losses match the input.
You could use a thermostatic switch to control the feed to the heater but you'd need to make sure the thermocouple was suitable for the environment the heaters used in.
If it reaches 80C in half an hour then chances are it will boil if left for longer. As above you'll need to use an electronic temperature controller or thermostat. What exactly is the application?
Reply to Water Tank Heater Temperature Control in the UK Electrical Forum area at ElectriciansForums.net
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
At Electrical2Go, we have recently broadened our product range to include water heaters. Our goal is to offer comprehensive solutions for both...
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
